There might be a clue in the 2 ohms. Measured from the near side terminal, that is too much, and you should substitute another relay to see if the resistance changes. It is only just less than the hot resistance of a headlight lamp and much too high for circuit before it gets to the load. If my Ohms Law is correct, at that resistance, a 7 amp fuse wouldn't blow as only 6 amps would flow, if you shorted the cable to earth. Measured from the right-hand side it is about right for the complete circuit including the screen element. The earth to the right hand strut hasn't broken off has it? This is quite common. The HRW earths through the strut which has a short length of sleeve that lifts the sliding contact from the rod when the tailgate is closed.
