Rear Engine Cooling Fan
- Thread starter Image
The workshop manual says:
After-running of engine compartment fan
If the ignition is switched off and the engine compartment temperature is more than 60°C, the DME control module remains in readiness for another 20 minutes. During this time, the engine compartment temperature is retrieved every 10 seconds. If the engine compartment temperature is >85°C, the engine compartment fan is switched on for 20 seconds. If the engine compartment temperature is still >85°C after this time, the fan remains on for a further 30 seconds.
Edit: The engine compartment temperature sensor is item 2 on the diagram:
ORIGINAL: JFK
I have a similar problem on my 997C2S. Did you get this sorted and if so how ?
I'm with you on the continuing worry...
JFK
997 have had a workshop campaign to disable the slow speed operation of the engine fan. For what reason, don't know!
