Rear fog light problem
- Thread starter arny1000
To remove the switch you must remove the cold air blower unit under the front bonnet,
First check the fuse this also powers the front fogs, do your rear fog lamps hang down under the rear bumper,
If so the the two wires come in under the n/s rear bumper test to see if you have power and earth,
The lamps often lose earth,
