Help please.
I've been bringing my newley aquired 964 up to spec from a lack of use and long period of neglect and thought it was finally ready for an MOT. Now booked for tomorrow morning.
As a last cleaning job today, I took the rear centre reflector and lamp assemblies out and cleaned them up of all the condenstaion and dirt etc. On completion I thought I'd better check all lights are working OK and found the rear fogs are not working. The dash switch lights up when the headlights are switched on, but goes out when pulled to turn on the rear fogs. I presume this is correct to show they aren't working?
I've checked and there is no power at the connector at the back of the reflector assy. The fuse and relay, which are shared by the reverse lights are obviously ok as the reverse lights do work.
Does anyone know if there is a common fault that I can look for? I was going to try to get the the back of the switch in the morning to see if a wire has come adrift, but is there anything else I should be checking?
Thanks,
Bob.
Thanks,
Bob.
