Rear hatch pins
- Thread starter Alpine
edh
4 other possible causes
Pins just need adjusting
The locks themselves may be worn or seized
Struts very soft
Tailgate seal needs replacing
Over the past 3 years I have replaced all the components - my hatch is now rattle free [
ORIGINAL: Alpine
I have a terrible rattle coming from the rear and I guess it is the hatch pins that are worn.
How easy is it to change them? I assume you only need to change the pins on the hatch, and not what they clamp into in the body?
I had to dremel a slot into the cheesehead screws on mine as they were completely siezed up, then used a massive screwdriver to remove the complete block that the hatch pin was attached to. The pins were also rusted solid onto the "rubber" blocks so I had to replace those with new ones and new cheesehead screws.
After that it was just a case of:
- Adjust pins.
- Tighten locking nut.
- Shut boot, if it doesn't shut easily or not at all the pins are too short, adjust them to make them longer.
- Give the boot a good tug [
] up and down (on both sides) and see if there is any movement, if so go back to step 1 until its nice and tight and shuts relatively easily.
Dave K.
PS. You may also need new locking mechanisms as they become worn over time, I think they were about £20 each last time (I only needed one), clean them and lubricate them with some grease/wd40.
Fat Albert
I spent ages greasing and adjusting my hatch pins to try and eradicate what I thought was the hatch sqeaking, only to find it was the exhaust!
(Obviously the 2 minute job to adjust the exhaust turned into a 1 hour drilling out of the snapped rusted studding on the hanger[
sawood12
Alpine
I've found these on e-bay
http://cgi.ebay.co.uk/PORSCHE-924-924S-944-968-HATCH-PIN-KIT-BRAND-NEW-GEN_W0QQitemZ350208136730QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item518a08161a&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1689%7C293%3A1%7C294%3A50
am I right to think that I need to undue the rubber block, and then these fit inside? The securing nut on one side will not budge, but does that not mater as long as I can get the blocks out? Am I likely to need any other parts other than these? Sorry to be a bit dopey but I'm not that great with a screwdriver and I don't want to have a go and be left with a boot lid that I can't close, which is likely to happen knowing my luck !
944 man
Simon
mr brightside
I did this job recently, the whole block has to come off by undoing the two torx screws which were factory threadlocked so make sure you're using the correct size tool cos if you strip the heads you'll have to drill them off.ORIGINAL: Alpine
Also if you change the latches like i did don't overtighten the mounting nuts or you'll squeeze the latch casing onto the internals and sieze it up, this happened to my old ones. I set up the pins using a ruler then made final adjustments individually.
