Rear Hatch re-bonding - Recomendations Glos
- Thread starter ianreeves
pauljmcnulty
ORIGINAL: ianreeves
Well, I think the time has come[]
I need to get the rear hatch re-bonded on my car, its fitting badly and noisy, also as the car is outside I get a small water leak.
Can anyone recomend any company to do this, I am based in the Cheltenham area.
Assuming you don't mean the rubber seal?
I'm interested to know the age of the car, and any other factors that may have contributed to the problem. If there's a time factor in the degradation of the hatch, it will affect us all!
I would guess mine may have been caused by leaving the hatch open in strong side winds, but as it had occured prior to me owning the car it is just a guess.
Tony
idwoodvale
ORIGINAL: Mikie_gb
Autoglas Edinburgh stuffed up my A pillar interior trims on both sides, threw away the spacer blocks under the screen leaving the holes exposed and rusting, and left bulges of sealant on the interior of the screen. I would strongly recommend standing behind them with a solid object in hand to coax the best work out of them.
I just find them ludicrously expensive - quoted £700 for a 944 Lux windscreen.
