My rear heated window hasn't worked for a while now and I noticed one of the wires that goes from the rear hatch strutt to the heating element was black and brittle so obviously an issue with the current/voltage going through it, this is not the problem however!! When I pulled the wire off the connector that is soldered onto the heating element it came away [
](the tab that is) can this be soldered back on or perhaps glued back!!??
Any help would be appreciated chaps.
