Jinxy
Hi Guys, I replaced my rear tailgate struts last week & made sure the struts were fitted the right way around as I know they are sided, boot light works fine & after faffing about a bit last night due to no heated rear window ( loose strut sockets on both struts ) I now have a working rear demister again, however.... ive noticed that the right hand strut top gets warm when the demister is switched on, is this normal ?, im assuming the earth is through the ball joint into the hatch frame ? if so the ball appears to be very clean & free from debris even though common sense tells me there should be some lube on there as its a ball joint ? any help really appreciated, cheers, Tony
