Having just read the latest edition of the Porsche mag I have a question about the small extra blower fitted to the heater system which helps to blow hot air to the cabin which is situated on the top of the engine on the left hand side.
I know the motor works as I have run a direct feed to it but somewhere along the line there is a fault, could someone tell me where the relay is situated and is this motor supposed to work when you turn the control knob between the seats?.
One other quicky, the senser that fit's into the rear heater pipe by the left hand butterfly valve, is this supposed to be fitted into the metal part of the valve or can you get away with fitting it into the red heat resistant pipe if sealed properly, assuming it locates before the valve and not after, sorry chap's but this is all new to
me!!!
Thank's Baz
me!!!
Thank's Baz
