Rear Light Panel Help
Pickled Piper
Can anybody explain how I remove the reflective panel incorporating the reversing lights. I've noticed that one of the reversing lights has some condensation i it and I would like to disassemble it and clean everything up.
Thanks in advance.
PP
from memory,, as I have had same probs,,
there is a black plastic trip panel that has three screws on it,, that you access once the engine lid is open,,,, then, another three screw underneath that (might be four),,,, then it simply lifts out,,, they can be stiff, and the end lights push outwards slightly to let it come out,, watch the paint on the bumper as when you pull them out,, they suddenly let go,,,
lights all just un plug,,,,
when you are taking the sencond set of screws out,, be sure that you are not unscrewing the adjucment screws as the panel has adjusting screws on each side so it can be set level with the bumper/engine lid...
cheers
scott..
