whinbush
Hi all just wondered if anyone else has had an issue?
When I took delivery of my 981 in Oct last year within 50miles I had a " check rear light" warning come on.
The indicator on the rear right had failed! Porsche had it replaced and all ok until last week the same again.
It was replaced yesterday and Guildford OPC are saying they haven't seen any others with this issue?
Also worth noting while it was in they did the following " Recall work "
WD06 (is the 6th Workshop Campaign for Porsche in year D (2013)):
Replace 4 drain plugs under the car. The car needs to be raised and some of the underside covers need to be removed.
WD09 (only for PDK equipped cars):
Reprogram the DME control unit on PDK. Requires the use of PIWIS
The PDK is a bit different after the update as it has to relearn my driving style again.
