rear lights from turbo/ wheels from turbo
silver7
does anyone knwo if the rear lights from a 993 turbo will fit a narrow body 993. Also will the wheels from a turbo fit a standard 993 to use for track days?
thanks in advance
Don't know about the light.
Front Turbo wheels will fit as same size and offset. Rear Turbo wheels will not as they stick out too far as offset is 40 on the Turbo versus 65 on the NB car.
Ian.
thanks very much - will have to check the offset on my current wheels as car is 993 rs - maybe offset is different?
Offset of standard 993 and RS should be the same for 18 wheels.
Turbo and S models are the ones with the lower offset on the rear.
Ian.
I have fitted turbo rear lights to my narrow body Targa and it's a straight swap. I now have white front indicator lenses and red rear indicator lenses as well as white side repeaters and I think it improves the appearance
Stewart
