Rear plastic timing cover Wanted
pegasus
Hi there, I removed the top plasic timing belt cover on my 1990 s2 to have a sniff around prior to changing all belts and rollers next month,I could not remove the top bolt on the bottom cover as the brass insert is turning with the bolt,I tried holding it by pinching the plasic cover and the insert with mole grips but it is still turning with the bolt, can anyone sell me a rear cover in good condition with all the inserts intact as I think I will have to butcher this one off,I had a look on ebay but could not find one,many thanks in advance, John.
Check with Exeter Porsche Centre 01392 822800
I had the exact same problem a few years ago and a new one was less than £20 back then. [:)] Could be much more by now but if you don't check you'll never know.
