I have a 1996 3.2 carrera gp white original condition. The wife wont let me take the kids out without rear seat belts being fitted (3 point harnesses). Can anyone help with any suggestions. My main concerns are financial and not damaging the car whilst fitting. I`ve got basic DIY mechanical skills. Thanks for any help
I`ve now bought the belts (3 point static) and intend fitting the rear clamp on top of the parcel shelf (to prevent cutting slits in the parcel shelf). I`ve drilled the holes for the bolts through the parcel shelf but the bolts supplied are not long enough. This is because the speakers lift the parcel shelf approx 50mm. I`m intending getting longer bolts but I`m wondering if the belts will be safe as the strap will only be connected to a bolt that is not tightened fully down. The problem I`ve got is I do not want to have to cut slits in the parcel shelf (if possible) and I have already drilled the holes for the top connections. Can any body help?
