Tizzy
So other than stating the obvious - getting someone to follow you! Is there any way to check that the rear spoiler is going up & down properly? I raised mine today to clean the rubber bellows and then didn’t lower it when I took the car out for a little blast round the Vale of Belvoir, when I got back home the spoiler was still in the raised position. From memory even if you manually raise the spoiler it then retrached when the car is driven. Any suggestions much appreciated as always!
thanks Chris
thanks Chris
