rear spoiler
- Thread starter Guest
I had a similar problem, and it was the microswitch that needed cleaning
Details are here: http://www.porscheclubgbforum.com/tm.asp?m=165336
Steve Brookes
Moderator
ORIGINAL: ruane
Rear spoiler has stopped working, light on dash showing fault checked fuse thats ok, any help much appreciated.
First thing to do is to see if you can raise it manually from the console switch. When it happened to mine I found that it wouldn't. That lead me to discover that the drive gear had fallen off!
Dave Wilkinson
Steve's suggestion re. the switch is the first to check. If that's OK the focus switches to the controller and the speed signal. I've seen the speedo affected by the classic "clock" connection problem before and it's worth checking out before assuming it's the controller 'coz they're over £200 each!!!
Dave
Steve Brookes
Moderator
