Rear spoiler
Morning chaps, anyone know if the spoiler is adjustable on its mechanism, as I have noticed that mine is rubbing slightly against the engine lid on the bottom right hand side(looking from behind)
+1, mine too, top left. I came to the conclusion no adjustment so ended up filing / sanding a few mm of the plastic away from the upper corner underside/edge (and then a few coats of touch-up paint to blend in) just so it would stop rubbing the paint away on the engine lid. Completely unnoticeable paintjob. Also the spoiler sits flush around its periphery, no longer skewed slightly, and the 3-4 mm gap is maintained all the way round when lowered. Graeme
Hi There are spacers under each side , mine had 3 each side. By removing 1 or 2 it will lift the spoiler .
