Rear stone noise
- Thread starter Guest
I have noticed that on BMWs, Merc, etc. you get very little stone noise.
I used to have a couple of Nissan 200 SX's and these sounded worse than the 996.
I think it is quite normal to hear the stones.
You have plastic wheel arch liners, so the stones will not damage the inside of the arches. The only issue might be chipping on the rolled edge of the wing, but this is true of any car.
I assume the noise is down to being a coupe (since this body configuration seem to make more noise in my experience), the wider/software tyres that tend to pick up more stones in the first place than a normal saloon, and the reduction in sound proofing necessary to keep the weight down and allow more of the engine noise in []
I wouldn't imagine any solution is possible, since it isn't really a problem.
If you have heard a stripped out car, particalarly a rally car, you will see the difference a bit of foam/felt and a bit of carpet makes.
