Brian_Innes
You're right. Worn or brittle rubber bushes the likely cause of suspension creaking. They have a finite life, and may well need replacing at around your car's mileage. It could well be the rear suspension strut top mounting bush that's creaking.
A competent specialist workshop should be able to identify the offending bush and quote for a replacement.
It's up to you who you get to do this work. I would get a quote from a reputable independent route as well as the OPC. Best to ask the indy if they have done this type of repair on a similar Porsche before.
Hope this helps.
Brian
Hope this helps.
Brian
