Rear Suspension Prob
steves944
Had a peek under my 944 at the weekend and discovered that on the n/s rear the bolt holding the shock absorber had sheared and left a stud in the casting of the hub. Handling still seems OK.
How am I going to get that out?
Will either need drilled out or build it up with weld and use a set of mole grips to get it out. I would use the weld option myself as the latent heat always helps get the remains free.
Alasdair
