rear tailgate motor clicking
- Thread starter pitzey
If this IS the case (which is very common as the cars get older) then some new gas struts will solve your problem.
Alternatively, it may be that the mechanism really isn't releasing. The solution is to get inside the car and pull the cables to force the catches to open, then dismantle everything, clean it, lubricate it and put it back together. Then adjust it so it does release properly. The catches on the car can be dismantled by drilling the rivets out and all the 20-year-old crudded-up grease cleaned out. Doing this, along with a good clean of the mushrooms on the tailgate, should restore it to perfect working order.
Monkeythree
On mine it was the little white plastic linkage block which had popped off and vanished. They are a matter of pence from OPC so don't be tempted by the hilariously overpriced ones on ebay.
ivortheengine
PSH
ivortheengine said:will new struts be powerful enough to raise the hatch on its own,or does it need lifted manually?
new struts should be able to lift the hatch on their own..both my hatch and bonnet lift themselves once released...the hatch can be tricky if one catch catches....the bonnet shoots up as soon as it's released from the latch....much to the surprise of the MOT inspector a few weeks ago....
Pete
PSH
pitzey said:I have noticed when i open the tailgate it sometimes does not close properly , one latch will take the other does not .
You can usually fix this by adjusting the pins, try shortening the pin on the side that it's catching. Only do this in small steps, though, you don't want it too tight or this can lead to not being able to open the hatch. Be careful whilst adjusting the pins, try spraying some penetrating oil on the threads first, the nuts will probably be fine but it's the pin thread into the hatch that can seize so be careful.
Pete
