REAR UNDERTRAY ON or OFF?
- Thread starter Guest
lee fulford
lee
lee fulford
Mine is off because it doesn't fit with the full Cargraphic system. But if the standard system was fitted I would almost certainly leave it on....As you so rightly say...Airflow
lee
Just because the factory fit it doesn't mean that it should stay on. Remember the RS was not tested to the same extreme as the regular C2, running non stop in Nevada or whatever. Why do you think the 175mph Turbo 2 does without this 'airflow' feature?... because cooling was even more of a problem on that model.
It also leads to parts prematurely failing, rather than failing instantly - so the damage creeps up on you.
Just what I've heard; it may be b*llocks of course!
lee fulford
Your far too educated for me.......I'm bailing out on this one...
Lee
Didn't like those stupid undertrays anyway
ORIGINAL: lee fulford
Domster
Lee
Lee, you undoubtedly know more about RSs. I just regurgitate more hearsay, that's all []
Either that or I dreamt it along with Desmundo putting the RS out to pasture. []
They got a lot right, but some faults took ages to materialise...
- Dizzy belt failure in 964s
- Dual mass failure in 964s
- Wiring loom self immolation in 993s
- Porous blocks with 996tts
etc.
And the rear undertray may also have been retained for a 'compromise' reason, such as drive-by noise requirements.
It does stop the oil drips on the drive tho' []
