Hi all, any ideas about the following:
993 C4 MO30 suspension with H/D bilstiens.
New rear discs fitted.
Suspension / bushes / wheel allignment checked by Centre Gravity - all ok.
Wheel balancing checked etc etc.
The car always seems to have a slight vibration at speed from the rear at speeds of 80mph +. There is a strange vibration that occurs from time to time. Suddenly whilst, say pulling away from an traffic island or similar, the rear of the car starts to vibrate ( when it first did it I thought I had a flat tyre).As you accelerate it stays with you, through the gear changes etc. If you coast or dump the clutch it is still present . It will not go away until you bring the car to a holt, engine running still, pull away and then its fine again for a few days or anything up to 200miles ish.
It is almost like something has been thrown out of balance and once it starts it wont stop until the rotation is stopped. Then it is fine again.
Has anyone experianced this.
I am having the drive shafts checked and the engine mounts checked as I believe these are oil filled and can loose there pressure.
Stephen
Stephen
