Rear wheel bearings
Anyone ever replaced the rear wheel bearings on their car? Either themselves or got a garage (independent or OPC) to do it.
1 needs done I was thinking of just doing both, beru are doing the bearings for £28.
Was it a pretty easy job?
How much did you pay?
Never had a problem when I had my 944 S2.....
But how easy is it to fit????
I relied heavily on this excellent site.
It tells you how to do rears. You have the aluminium trailing arms - As the site is American some of the terms are different such as 'rotors' for discs etc....... Read the blurb and it will give you a feel for how confident you are in your abilities. Oh, and whether or not you have a blowtorch/big oven, effing great bearing puller and a 4 pound club hammer.
http://www.clarks-garage.com/
Good luck, let us know how you get on and how long it will take for your flattened fingers to heal
I have done one of mine - and the other has just started getting noisy - it is mostly possible with the right size drifts etc. without removing the trailing Arm - but once I had the hub off I had to take it to my local OPC to get the outer bearing race out. You have to split the CV joints and remove the driveshaft dismantle all the brakes etc.
Tony
Tony, is yours an earlier model? I think the later ones have a single race on the outside of the trailing arm. Once the driveshat is out the way then its amatter of either a puller and some heat or a puller and lots of heat and a big hammer or Dealer!
No 1990, in the removal operation half of the inner race stayed with the hub and it is difficult to remove without the correct tool, OPC charged £12.50 +VAT for the job.
Tony
Well I made it easy by making sure the hub was clean and delivering it to the service dept.
Tony
My first thought is heat. Heat up the bits you want to remove with a blow torch (or gentle with the Oxy acet torch) and hopefully different metals will expand and the remains of the bearing will come out more easily.
Also try alternating a blow torch to heat up the bearing remains and cool quickly by squirting on WD-40 OR PLUS GAS (be careful, fire risk!) the heating and sudden cooling may shock the parts and break the bond.
Thanks for that. Did try it yesterday but I'm working outdoors so had to contend with some wind. I'll need to wait for a calmer day! Rgds, Ken
In that case, heat up remains of bearing with blow torch and allow the howling gale/wind/driving snow shock cool that parts[;)]
Rather you than me working outside this time of year!
I think the trick that Indie's use is to break the cage with an air powered cold chisel - my Indie says it is a very quick job!
When my rear wheel bearing was replaced a few weeks ago I know a lubricant was used when the new bearing was pressed into place a little like grease but when friction makes it hot it sets like a resin maybe this bond is still strong [8|]
my bearing knocked out quite easy but it was well worn and corroded so perhaps the best way would be to split it............. if it will
I helped a mate when his wouldnt move, though the solution was that he hadnt spotted the big circlip amongst all the cack holding it in lol. Poor light was the excuse. Easily done tho.
Good luck
Please don't beat out the old bearings!
The hub is aluminium, the bearing is iron/steel based, the two expand at different rates, heat it all up and it will slide out.
Beating it out will make the job hard for the next person who has to do the job and beating the new one in will stand a chance of stressing the new bearing.
Just because 944's are not worth a fortune these days, they are still a great car, I hate seeing them not get the respect and care that I think they deserve.
Thanks for all the info. I applied a puller to the hub and gave it a prolonged dose of heat - it then popped lose so hopefully I can do the same on the main housing. Just working outdoors in this weather will probably be challangeing!!!!
The only proper way without damaging the shaft is to grind through most of the way and use a chisel on the bearing anything else will risk damage or changing the temper of the shaft.
why on earth don't you take it to a local engineering workshop where they have all the proper presses and tools to do the job properly. What's it going to cost ? £40 as apposed to £100's for a replacement shaft or wishbone arm.
I really don't understand why it is worth all that effort and risk to save such a small amount of money to do the job properly.
Because it's a project car and I like doing things myself. I appreciate the comments about too much heat but I am only using a fairly simple blowtorch which should not have any detrimental effect on the components - maybe a bit slow but I'll get there evetually!
I suspect that it's a question of time, or timing. See if you don't drive your 944 to work you either have to get it done on the weekend (not many engineering shops open on a weekend I suspect) or take a day off to do it, which being self employed as I am would have a direct cost. Still that didn't stop me yesterday and now the car feels much better for its full alignment and my dentist was pleased to see me too.
ORIGINAL: peanut
ORIGINAL: James_G
yes I can see what you mean. I'm self employed and every hour I don't work is an hours pay I lose.
I used to do everything myself on my classic cars, diffs g/boxs the lot but now I appreciate sometimes you save nothing by doing it yourself in fact it can cost more in time and breakages etc. Any garage has a decent press these days . It saves a lot of mucking about. My garage did my rear bearing for £40.00 + vat. i supplied the bearing .
