rear whell horsepower
- Thread starter Guest
Ergo I would expect my 211BHP S2 to deliver 211 HP to the wheels (when new anyway), and presumably more than this at the flywheel - where the actual figure is interesting but pretty irrelevant [8|][8|][8|]
mik_ok
Horsepower is a work rate. You measure it by applying a braking force ~ hence "Brake Horse Power". This is whether you use a std wheel dyno, or an engine dyno (with the engine on the bench).
At your local dyno, what you actually measure is torque generated at the wheels.
You calculate BHP given that :-
BHP=(Torque/5252)*RPM
{assuming your torque is measured in lbs.ft}
You then measure driveline resistance and estimate the actual figure that the engine must be producing to provide x at the wheels.
All manufacturers rate their engines ~ what arrives at the wheels is less.
sawood12
This is why comparisons of power output between different dyno's is largely irrelevant as there are different assumptions and mathematical algorithms used to calculate your flywheel power. When using a dyno to quantify the effect of mods you should always take it back to the same dyno every time. The actual figures might only be an approximation and not 100% accurate but the relative increases in power should be.
You think this is complicated - you should try aero engine test beds on for size. The physics and mathematics involved is a science in itself!
(edit - The 'IT crowd' and 'My Name is Earl' Fen)
I bow to your expertise guys. But Horsepower is a measure of power, as is Brake horsepower. So why the need for the distinction. And ultimately, isn't power as measured at the flywheel a totally pointless figure - what we are interested in is the power at the wheels.
Must confess that it's a long long time since I last talked technical engineering stuff, so I'm probably wrong.
mik_ok
We are of course only really interested at the figre that arrives at the drive wheels, as it provides the motive force. It's the torque arriving at the drive wheels that we are interested in - power figures merely indicate the advantage you can take of gearing to maximise this figure. If you are now wondering what the hell I'm on about, and have 5mins - READ THIS. [
Car manufacturers use engine dynos when developing their engines though, and everybody therefore rates the output of the engine. Which makes some sense - othewise the same engine used in different cars would have differing power ratings. Also the driveline losses change slightly depending on the gear you are in......
sawood12
But I have become distracted from this by the fact that the front of my engine is all wet [
Almost definitely coolant leaking out somewhere. B******ks !
I don't think it's anything relevant, but there appears to be a place to put a pipe on the (now wet) plastic cover (front of engine) which goes over the cam belt and there isn't a pipe on it. Not an obvious place for coolant to go into though.....
