Hi folks, the rear window heating element has never worked now since I've had the car, I can live with this but now the rear wiper has stopped also. The motor gave up the ghost a few months ago and I fitted a new (second hand) one, it worked fine for a while, then worked occasionally and now not at all [] I thought it may be the switch so I've checked this weekend and I have power at the switch and at the motor but still no movement! However when I've checked the fuse box there doesn't appear to be a fuse for the rear window, just a relay which is in position G3 and is also the fuse check relay with the green led on it and it doesn't appear to be working!!! I placed several good fuses on it and no light!! So either the led is no good or the relay is shot, could this be related to the problems with my rear wipe?? All it says in the relay guide is Rear Window/Fuse Check.
Any ideas lads?
Any ideas lads?
