Reat Toe Adjusment
Frenchy
Can anyone confirm that the rear toe is not agjustable on Koni MO30 cars ? i have been cleaning the geometry adjustment bolts and slackening them off today with a view to 968 castor mounts and geometry set up next week.
There is no adjustmet bolt fitted to my car.
ORIGINAL: Frenchy
The toe is adjustable on both front + rear suspension. Regardless of weather its M030 or not. All 944,s + 968,s are fully adjustable...
ORIGINAL: Big Dave UK
I think it's all Porsches are fully adjustable - I don't think there are any that aren't.
Frenchy, there will be an adjustment bolt. Look at the Porsche manual. It's there, on each trailing arm. If the geo place has any experience of 944's then they'll be able to point it out to you immediately. BUT it's worth soaking it in PlusGas (or similar) in advance as they often seize.
