Chaps,
I'm not sure what I'm asking with this post, but will carry on anyway ... [
My S2 has failed the MOT again on emissions. High CO. Same as always. The tester was careless enough to put the probe in another car hence my car passed, but I'd like to solve the problem properly.
The same happened last year and I seem to recall that I did some things to make the CO readings come down, but they were still pretty borderline. I am strongly suspecting the AFM is nearing the end of it's days. It is 180,000 miles old and operates by pushing a flap in an airflow against a spring, and my suspicion is that the spring will lose it's springiness with time allowing the door to open more than it should and hence flowing more fuel, running rich and putting the CO up.
Taking the AFM apart and cleaning the tracks is a simple job, and one I have done before. What I am wondering is whether it is possible to tweak the spring tension up slightly, reducing the door opening and thus leaning out the mix and lowering the CO. Is this possible? Advisable? A very bad idea? Has anyone tried this? If so, how did you get on?
I know that re-built and re-calibrated AFM's are available, but they don't offer much change from £400 and that's a fair chunk of lolly. Does anyone know of a way of doing this cheaper?
(Alternatively, does anyone have a spare known-good AFM and an exhaust gas analyser, somewhere near London?)
All input to this ill-formed question welcomed ... thanks.
