As some of you may be aware, I decided it was time to have my engine head on my S2 Cabriolet de-coked and rebuilt, as some of the lifters were gone and it was a bit noisy (the doormen at the club where I work said I had the only diesel Porsche they had ever seen!!)
When my mechanic had the head off, it became apparent that the damage to my engine was a bit more sinister than first thought. The engine had been pushed hard while cold and the pistons had gouged out lines on all 4 cylinders. I checked out the posibility of having the cylinders re-bored, but as the engine is a " nickerseal" (or something that sounds like it), it is only Cosworth and a place in Andover that could re-bore.
Feeling dpwn in the dumps, I called Porsch-Apart in Bury adn they had a " small engine" (bottom end) which had only done 73,000 miles and was mechanically sound. I arranged for this to be sent to my mechanic and and then picked myself up when I found that it was going to cost me £964.00!!
Well the engine arrived and my mechanic got my existing engine out and got to work making one engine from 2. Once all was out, it was obvious that I needed a new clutch too, so the costs were spiralling, and to add to that, I needed new front pads and disks.
Well I got my car back yesterday and the noise difference was immense, all you can hear when the engine is ticking over are the injectors and belts and it has a fantastic throating roar when driving.
And it was quick before, but now, wow, what a difference!! My mechanic has worked wonders and in my eyes is a magician. All the cables tied properly, the engine and bay steam cleaned. Have a look at the pic and make up your own mind. I am now £3,194.00 worse off, but there ain' t much more that can go wrong!! Le Mans here I come!!!
I look forward to hearing your stories guys
