Recaro pole position seats
- Thread starter blade7
As you are no doubt aware, there were some aftermarket rear seat deletes available but good luck finding one now. I had the rear seat area covered in a bit of light sound deadening and then black carpet. It’s not as good as a moulded job would be but the trimmer did a reasonable job - most of the joins are hidden by the mounts for the rear cage anyway.
I was leaning towards PPs for my car but I booked an appointment and went to GSM Sport Seats near Nottingham on the way to the NEC Classic one year. I played Goldilocks by sitting in about 50 different seats until I found one "just right" the PPs were too narrow around the shoulders and my upper body was too long for the shoulder straps to locate properly. If you're just using a 3-point seatbelt then that won’t be an issue.
blade7
Well-known member
Front seats are pretty heavy so something lighter will save a few kilos.
Tony
