The switch to release the hatchback on my Targa stopped working today and I suspected it may just be a fuse. On the way to buy some spares this afternoon I had a brainwave/ failure... I tried the sliding glass roof panel to see if that was also affected. Well, it started to initiate the move backwards and I immediately pushed the switch to close it. This only resulted in a click from the motor at the back of the hatch but no movement in the roof panel. I could continue to open it, but not move it the other way. The car manual states that you can manually close the roof using two large allen keys however, having tried, it seems to me that the allen keys will break before any movement will occur in the glass panel - seems completely immovable (there may be a special knack to initiating the movement). So now I have a very slightly open - secure but not watertight - roof and no electric control over either the hatch or roof panel either by means of the sill mounted switches or the key.
I normally use Machtech at Kings Langley to service my car but I thought it would be prudent to ask here if there are other companies better suited to fiddling with electrics - rightly or wrongly I associate Machtech with the mechanical side of things. I'm based in north London, so it would be great if anyone can provide me with a strong recommendation of someone not too far away - even if this is to return to Machtech!!
Any suggestions would be much appreciated.
Peter
Peter
