My centreforce clutch kit is just starting to slip.
I plan to re-use the centreforce heavy duty pressure plate as it has done circa 15k miles only and it is likely to be just a worn plate as there is little "meat" on the clutch plate from new.
The plate will need to fit a G50 spline, but I am pretty sure it is the same spline as used on the 4 speed box.
I have tried a puck plate in the past (and after 1000 miles, never again!), so need a high grip plate that will help hold 550llb ft torque.
Any recommendations?
