Reconnecting the indicator
944Scott
Whilst fiddling with the indicator I have managed to accidently disconnect the connector hanging out the back (on the drivers side) how an earth do I reconnect it ? there's am oil cooler and power steering cooler pipe set up below it and I just cant see how I'm going to get to it.
Any ideas guys??
Sorry, but the only time I had that connection off was when removing the front PU. I think you may have to do the same to get at it...
There's a how-to guide HERE.
Actually - after looking at the guide - you might well get away with just removing the "batwing" - the plastic undertray immediately behind and under the bumper. See picture #3 in the guide.
Thanks for that. batwing off I managed to get my hand up there and loop and extended cable tie around the car side end, then I push the indicator end back through the hole, pull down hard on the cable tie which squeezed the connector between its surroundings and just gave me enough room to push the connector back on.
