Red Master Key?
harvey
I am looking at a 2 owner 1995 car that doesn't have a red master key. Should it have had one in addition to the two black keys? Many thanks, Harvey
ORIGINAL: harvey
I imagine so, my 1997 'S' has the red master key and a mate of mine's turbo, which I think is a 95 car has a red master key so I guess you probably should Local independant or OPC should help though and I know you can get them retrospectively (I know someone who did).
2 owner car from 95 sounds promising!
Thanks for the thoughts, the chap selling has had it for 10 years and bought it from an opc with 2,000 miles on the clock. He has kept everything very carefully, and doesn't recall ever receiving a red key, I wondered if perhaps the earlier cars didn't come with one.
If it's a PA1000 alarm then it should have a red master key. If it's a PA2000 alarm then no red master key.
Ian.
ORIGINAL: ian_uk
Ian.
Thanks Ian, straight forward, simple facts, I like it
My '95 C4 Cab had no red key and has PA2000 alarm
The car has a little immobiliser fob which you insert into the dash just before putting the key into the ignition....I presume that is part of the PA2000 alarm? Many thanks for the help all.
No it's not part of a PA2000 alarm (or PA1000 either). The PA1000 and PA2000 alarms have no little part to insert into the dash. They work directly from the buttons on the fob.
What you are describing sounds like the previous Porsche system which was fitted to the 964. This was a CAT 2 immobiliser only which has a little piece you insert into the slot in dash or consol.
So the car could have just an immobiliser (Porsche or aftermarket) or maybe an immobiliser plus a third party alarm (as there would be no need to have the slot with a PA1000 or PA2000 alarm).
Ian.
Ah, OK this is beginning to fall into place
I think the early 993s got the old system from the 964 so I stand corrected on my earlier post.
my cab has the little dongle tag thing too plus a switch in the centre bottom row of the console in front of the handbreak. I believe this switch disables the microwave sensors for the alarm mounted in the corners of the dash as it also allows you to lock the car without the roof auto closing.
My fob only has one button and looks fairly generic, there is also no mention of an alarm system in my option codes. So I wonder if the dealers were retro fitting their own systems back then?
Harvey, are you going to buy the car???
the 1000 system has a red key. you will not need it unless you loose both regular keys(!!) OR have to do some resetting (read the manual). Changing the "chip" and the two zappers is not expensive. I was going down this route with my car and out of the blue the red key was found by the original owner. It is a straighforward job for a good shop.
Harvey. You have a problem that i recently have had to contend with. Hope this helps:
A 1995 car may well have the PA100 alarm system (single button handsets, marked PA100) AND the immobiliser dongle (as with my TT). To get a replacement red master, you either have to replace or reprogramme your exsiting alarm control unit. Both of these options are still available from Hamilton & Palmer (who made and supplied them) at a very reasonable price. The job istelf is very straightforward as the unit (located under the drivers seat) simply plugs in to the cars wiring loom. No need to go to an OPC / specialist, I would say.
H&P are very friendly to deal with and provide a very prompt service. They told me that this system has proved very reliable in practice, but a fair few of us are coming to them to sort out the ubiquitous missing-red-master problem!!
good luck
tim
My car had three previous owners and came with two black keys but no red master. I was not aware that I needed one until some time after I bought it and so traced the previous owners and found that the first owner, a very helpful chap who had driven the vast majoity of the car's mileage, still had it at home in the drawer. A very useful exercise - not only had I found the red key but I had also established the car's full history, which I found reassuring. It almost seemed too good to be true but it didn't take a lot of effort. I had already spoken to Hamilton and Palmer who were very helpful and would have talked me through the process of getting the new master key if I had not tracked it down.
FYI - I replaced the control unit on my car this afternoon - and it was very easy. Pictures soon on www.911uk.com. Programming the new keys was also very simple. The only mildly hard bit was removing the control unit and the central locking controller that sits on top of it. These are both stuck down with a double sided foam sticky tape. Easiest way was to first remove the Nokia amp, then insert a blunt kitchen knife to prize the tape apart.
Best option of all though has to be to track down the previous owner who still has it!!!
ORIGINAL: tim993
A 1995 car may well have the PA100 alarm system (single button handsets, marked PA100) AND the immobiliser dongle (as with my TT)....
But why unless the PA1000 was retro-fitted at a later date? I can't believe this is how it would have come supplied from an OPC because the PA1000 system contains an immobiliser plus positive locking plus alarm therefore the dongle immobiliser would be redundant.
Unless you really mean PA100 rather than PA1000 and we are talking about different systems.
Ian.
Hi Ian - good point. I did not check which system was being referred to before posting - sorry!! My advice was for PA100 only - identified by the single button remote, I believe.
all the best
Tim
No need for sorry Tim ... good input ... it might well have a PA100 on it from the description. Never heard of PA100 before but now a little more knowledge gained :)
