pboldmonts
The above warning light came on last Sunday. Managed to get back home with what seemed to be an electrical type fault, miss-fire when demanding more power. Thought at the time it felt like a coil pack. Popped it into Porsche Solihull this morning. Turns out not to be so simple. Diagnostic shows a fault has been present for some time even though I and the "system" had not noticed. It was reset in the hope it would clear but as they reversed it off the ramp it came up on the display again. They want the car back but seem to think it's the high pressure fuel pump. Not a cheap part and not quick to fit either. Part is about £450 so glad I'm still in second year of warranty.
Guy in service said has only experienced two other instances, both on Cayman's. Mine is a C2S Cabrio. Anyone else come across this fault? Any other thoughts. Apparently they can't just order the part and fir it as, if they do and it turns out to not be the problem then Porsche will not pay for the part, the dealer will have to.
Just what you need with the weather we are having, not!!!
