Reducing lag?
- Thread starter u63af
944 man
sawood12
The most significant technology to combat lag is the variable vane's you get on the 997 turbo. These close up the gaps between the turbine inlet vane when off boost to allow expansion of the exhaust gasses at low RPM and open up as the revs rise. This is very expensive though due to the exotic material requried to withstand the high temps. The turbo's for a 997 turbo come in at around ÂŁ6k each. Would be a great mod for a 944 turbo though.
However even modern turbo's don't elminate lag. Modern cars (i.e. hot hatches) simply install smaller turbo's, but if you look at something like the Evo's with large turbo's you still get horrendous turbo lag.
You could always master left foot breaking which allows you to maintain boost pressure while braking!
944 man
u63af
If I were to send my turbo to turbo technics, get 360 deg bearings, and different profiled blades on the turbine then I was hoping that it would reduce lag a bit. Also the cat on my car must be slowing down spool up aswell. Would the current ecu cope with a lightly modified turbo?
I think one of the main problems is that my last car was a 5 litre tvr and it had a lot of power from about 1500 rpm.
944 man
944 Turbos are well and truly out of my system; but if I was looking to improve one then Id do the following:
* Improved turbocharger and up-pipe
* Manifold and up-pipe ported and lagged
* Replace the DME and AFM with a MAP based ECU
That done you can address other issues, such as charge temperature... It wont cost a deal more than people are commonly spending but the difference will be substantial I think. Im definitely not going to do it though; and if someone offered me a cheap 951 then I wouldnt look twice at it.....
Tony
944 man
edh
I'd have a chat to Jon Mitchell about your requirements - my bet is that a Garret BB hybrid will be a good option for you. It's a lot cheaper than fitting a 3l engine or an LSx (which would probably be exactly what you want).
FWIW, I found that the vitesse MAF improved the spooling of the turbo by a few hundred rpm, nothing particularly significant.
u63af
Took the car out today. With the boost controller off, it boosts to 11 psi and holds it to the red line. When I put my ebc on, it boosts to 16 psi as I set it but something doies not feel right. It feels like it is being limited. It will reach 16 psi and hold it but just does not pull right. I have chips so it is not reaching fuel cut. I used an old 3 bar FPR which I suspect may not be up to the job. Does anyone think that a dodgy FPR may cause this to happen? My thoughts on it may be that it is not getting enough fuel at 16 psi and was concerned I may melt my engine.
Neil Haughey
sawood12
Neil Haughey
Page 324 of Advanced Engine Technology by Heinz Heisler says this "It is important for effective cylinder scavenging that pulsed exhaust gas energy is introduced to the turbine wheel in contrast to a damped steady flow of gas" or thereabouts. He also says enough to fill a whole chapter on turbocharging/supercharging.
appletonn
After covering around 300 miles since fitting it, my backside dyno would indicate that the boost does come in slightly sooner (about 200-300 revs lower down) and it feels smoother as the hurricane gathers pace.
Could be all psychological of course or my old one was kaputt....[8|]
sawood12
ORIGINAL: Neil Haughey
Actually the inverse is exactly what you want.
Not read that book but from other material I have read I think this is more about harnessing the energy of the pulses in the exhaust gas flow i.e. improving turbo efficiency, which no current turbo can do, rather than combating lag. You also need a continuously active variable geometry turbo to change the turbine inlet area's to match the pressure pulses in the gas flow. This sort of turbo is the technology that will supercede VGT turbo's - if they can get it to work - and even then it will likely be horrendously expensive. With our cars we simply have to learn to deal with lag the old fashioned way.
Peter Empson
I'm not being very helpful am I []
944 man
nags
I'm aware that Lindsay Racing offer a reconditioned (exchange) turbo for what seems to be reasonable money, but they do come in for a bit of criticism. Is there something similar out of the UK or europe? Are there any ball bearing bolt-in replacement options?
