Just wondered, out of all the people who have removed their ref sensors, how many had the zinc plated 'figure 8' type washer underneath the sensor head on the rearmost sensor , between the plastic head and the bracket is probably a better description.
There are two washers listed, a thicker one for turbos than N/A.
I know Daves Turbo had one as he has recently had his apart.
My N/A did not have one and I doubt the sensor had ever been out since new.
I struggle to see what the purpose of the washer is ? The gap between sensor and flywheel when correctly set will not matter if you set it with or without the washer, if you set the gap with the washer in place it must always be there and vice versa if you didn't it doesn't......follow
So, the original questions, who's had it and what does it do ?
