Refixing top windscreen metal trim on 924S
vitesse
The nearside corner of the black top windscreen trim on my wife's 924S became loose some months ago causing me to completely remove it to prevent damage,complete loss.
Most of the fixing clips had rusted badly with 2/3 losing their grip.
Got a complete set of new clips from OPC Bolton(some delay due to their unfortunate fire) & finally refitted the trim last weekend.Waiting for them,I cleaned the windscreen reveal area including the rust stains left by the old clips rubbed down the affected areas on the trim & repainted it using satin black.
Applied a little vaseline to the contact areas on the trim,& fitted the clips 1st to the headed pins in the reveal-they slide on & are retained by a sideways slot in the clips.The trim then just pushes on vertically being slotted out to miss the pins being careful to get each end aligned with the side trims
