RELAYS - Help the ignorant
BLD
Do relays cease to function or blow and how does one test to confirm they are working or not?
BLD. Electrically challenged member.
yes they cease to function , I've never tested a relay in all the years I've owned my car , I just keep a few spares and swap them if I have a problem, however before swapping them for a new one , remove the suspect relay and spray electrical contact cleaner into the socket (don't use WD40), then clean the legs of the realy with emery paper or a small copper brush, this might save you some money but keep spares in the car, then on a journey if a problem occurs , (imagine the fuel pump relay suddenely fails) you can continue after a little road side DIY.
Maurice
Many thanks - a response which technically cruises just above my head but I will regard it during a quiet moment to see if I can test the relay which appears to be defective. In the meantime I have managed to find a couple of spares. Jolly expensive!!
BLD
