Chaps,
OK, one that isn't a problem ... yet ...
The S2 is getting sulky to start. Symptoms: it will turn over as briskly as ever, but not fire enthusiastically into life. It semi-catches, and sometimes will idle at a very low revs (not more than 3-400rpm) before dying. If it does this, it will always die - tickling the throttle doesn't make it pick up.
Sometimes, pumping the throttle when starting it helps, and it will start as normal. Sometimes it will start as normal anyway, without hassle. On each occasion, it has started at the second attempt. (I think it once waited until the third attempt.)
I'm not sure whether it is associated with hot starting only. I haven't tried it enough times to know.
The problem started very suddenly - this morning. It was fine yesterday. It has been driven long and hard in the last few days, and the ambient temperatures are high - mid to high 20's. However, it was as hot yesterday and didn't do it then.
It is almost the symptoms of fuel vapourisation, with the fuel lines near the engine getting too warm and the fuel evaporating. However, I haven't changed anything, removed any insulation nor removed any heat-insulating gaskets from the engine recently, so I doubt it is this. Other thoughts would be possibly some temperature sensor on the ECU has failed (common on VWs of the same age, but I don't know if it happens with Porsches?), or possibly the fuel pressure regulator (although I don't fully understand what this does, or what the precise symptoms of it failing are.)
I do have a spare DME relay, which I should probably try swapping. Any suggestions other than this - I'd be happy to hear them.
(The concerning thing is that this is being written from mid-France, half-way along the Loire Valley. Which is where the car is currently, on holiday! I don't mind it being reluctant to start as long as it does start, every time. If it packs up then I will be in the poo ... although I guess this is what you get breakdown cover for. Access to spare parts is limited as Porsche is a little-known brand in France, although I do have access to a local VW garage in the next day or so, if any parts happen to be common with VW or Audi.)
Thanks for any useful suggestions.
