Remove front bumper 997
- Thread starter joafog
you then needs to remove each front part of the wheel arch liner and behind the driver headlight is the electrical plug which needs disconnecting and behind passenger headlight if you have it will be the washer pipe for the headlight washers once disconected if not clamped it will let all the water out
on the underside of the bumper is a series of t30 screws along with one on either side facing upwards where the bumper screws to the wing, the indicator lights push backwards and unclip from the front if all is well then the bumper should come of, sometimes it gets wedged under headlights.
refitting is as removing but ensure the bumper slides into the guides where the indicators fit
john.newland
To remove the slide clips I bent a wire coat-hanger into a hook. Needed quite a pull!
dereksharpuk
ORIGINAL: joafog
Thanks, but it looks like I am not allowed to see this link!!??
access denied
//Joacim
You can if you join the Club []
garyw
Moderator
ORIGINAL: garyw
Just seen this... http://www.pistonheads.com/gassing/topic.asp?h=0&f=48&t=773023&mid=0&nmt=996 Turbo Front Bumper Removal - DIY w/pics
Thank you!
//Joacim
