Removing a 996 Battery
- Thread starter blueSL
Tool Pants
non Club member but v. knowledgable
We do not have this in the US. We just disconnect the battery.
Since your year has an electric front trunk release do not close it when the battery is disconnected.
Tool Pants
Sometimes when I go to my local dealer they have a car in the showroom with a charger like mine connected and the battery cables hooked up.
A well designed electronic control unit will be protected against over-voltage and reverse polarity but like the Cambridge Audio hi-fi amplifier which blew up when I intentionally tested the short circuit output protection and found it didn't work, it's much better not to go there.
Far better, as Mark Bennett says, is to use a battery conditioner which is a regulated DC supply which charges the battery first using a constant current supply to load up the battery independent of the voltage it is presenting, then a boost phase to ensure the battery is fully charged followed by a holding phase where the charger charges at constant voltage (13.6 - 13.8v) to keep it fully charged ("trickle charging"). These chargers can be left connected indefinitely without disconnecting the battery.
The 996 has sensible power saving measures to shut down electrical systems after a few days to prevent battery drain. One of my other cars, an SL55 AMG, will happily flatten one of its two batteries in 7 - 10 days so I always connect it to one of these chargers when the car is not in use. The make I use is called Mascot, Type 9640, available for about £27 online.
Elliot Davies
Inexpensive and does the job well
Use of the solar charger certainly worked, but at the time my car was parked outside in the light. I'm wondering if there would be sufficient light in my garage through the small window for the solar panel to have any effect?
I would certainly recommend them for use outside though.
I understand a higher capacity Porsche battery is available and this might be the way to go.
ORIGINAL: blueSL
you can route a cable down in front of the wipers to the area where the battery is.
That is how my battery conditioner is routed/connected.
Tool Pants
If you want to use the type of charger that plugs into the lighter socket and your lighter is in fact live, then look at the bottom of the door seal. There is a half-moon cut-out for the wire, so you can close the door with the charger plugged in.
Original: Toolpants
Doh, I've noticed that half moon before as I was wiping the seals and it never ocurred to me what it was for!
Lot's of good suggestions here, thanks everyone.
