Info
https://www.bosch-automot...l/-/product/0265006142
https://www.mister-auto.co.uk/abs-senso ... 5-006-142/
they were also fitted to the 964 from 1993, so you can use that as a search as well 944 606 401 02
they are all pretty much the same thing a Hall sensor, its just the package that changes,
so the one you are looking for might be 0 265 006 142, but the next number 0265 006 143 might not be for the 944 because the lead is 20mm longer but has the same sensor and plug.
so just start searching for number close then look at the pictures, you might find something with the same sensor but different plug, time to chop off the plugs and get the soldering iron out.
anything that better than the £152.00 genunine Porsche price is a saving and as the parts get harder to find you have to start thinking laterally to keep it all running
