Johnny C
I've got a terrible squeaking and knocking coming from the passenger airbag. 5 mins after starting it will start and it's constant above 5mph though it varies with road surface and quality. it's as loud as the radio.
Through various acrobatic manoeuvres on the motorway I've found that when I press the airbag cover in hard, it stops.
Is it possible to easily remove the cover? I'm assuming that it's probably held in with a couple of clips as it's designed to come out easily when you have a smash, but
1) am I likely to set it off and
2) how should I do it? Just lever it off with a flat blade?
TIA
TIA
