I need to change the instrument cluster on my 996 (mph to kph speedo). I have looked in the technical articles, tried a further search of the forum and made a request of the register secretary without success. Any advice (step by step instructions would be marvellous) and any pitfalls would be most appreciated.
Removing/replacement of instrument pod
- Thread starter dij999
Hi David
I assume you mean your post of Jan 1st see below.
https://www.porscheclubgb.com/forum/tm.aspx?m=964561#msg1046664
As advised in my reply it’s fairly easy and straightforward to remove the pod itself, just attached by two screws as per the You-tube link i attached to your previous thread.
Do you just want to replace the Speedo face with a KPH one? if so again lots of info on Rennlist.com or there are companies out there who will do it for you.
https://rennlist.com/forums/996-forum/460106-gauge-face-replacement.html
The digital readout is then changed to KPH via turning the time knob to the left for a few seconds.
Good luck
Andy.
