I noticed that the nearside rear tyre on my C4 had lost a few psi the other day so I took it to a local tyre centre to get it checked out. They found a small nail in the tread but refused to repair the tyre because they found a barely visible circular indentation around the inside of the tyre which they said was due to running the tyre at low pressure and was indicative of potential damage to the side wall.
I know that most people will say better safe than sorry but the tyre in question is barely 1000miles old and I have since found out that this particular tyre centre is known for turning a tyre repair into a sale oppurtunity. I also know from previous experience that the cost of a new tyre from them will be more than the usual supplier I use.
Any comment particularly on the reason for the indentation on the inside of the tyre which strangely is on only one side of the tyre rather than both which I guess you would expect if it had been caused by running the tyre at too low a pressure.
Oh yes, they've also damaged the rim when removing the tyre
