Replace ABS Sensors
Alan Stamper
ABS warning light on...and indeed no ABS...so thought I would replace ABS sensors as a first fix on my 97..any pointers on doing the work welcome !!
It is easy to do as long as the sensors come out in one piece. The chances are that they won't so you have the hassle of getting all the bits out.
To remove the sensor all you do is take out one screw and unplug the other end, then pull out.
