replaceing electic window mechs with manual?
jamescharnley
To replace the electric windows with manual ones is it just a case of locating manual mechs from an earlier car & swapping over?
James,
I'm assuming you're talking about an earlier - non-964 - car?? I'm sure you realise that all 964s have electric windows.
The door itself is the same shape as on earlier cars but I wonder if the internals are any different. You would obviously need the manual handle and adapt the door card to accept it. Then you would have to fill the switch holes - or leave the switches in place.
Is this a weight saving exercise or do you just not like electric windows???
Dave
I'm looking at doing this mod for weight saving reasons ( hoping to buy a 964 c2 in the next week or so and modify for the fast road / track).
I was wondering if this was an easy / common mod to do? I would be fitting RS style door panels at teh same time
The only thing I've seen done with this is RS door panels and Plexi glass sliding windows. ...Look on Rennlist for the light weight alternatives there's a couple of serious addicts over there, and I mean serious.
Edited to correct the manual window winder statement....
Kevin
The 964RS has manual window winders with thinner glass and - for completeness - the interior door opener is a piece of woven nylon. No central locking
Bob
James-speak to Southbound-I believe they can supply you with a least light weight doorcards and doorpulls and I'm sure the system can be modified to accept the earlier winding system. You could go the whole hog with perspex windows :)
