adrian996
I'm thinking of tackling the replacement of my front and rear discs and pads on my MY 2003 996 C2.
I've just had a major service with my local independent and he tells me that they are "unserviceable". The braking seems to be ok to me but he says that they'll fail the MOT (June) by visual inspection alone(?). I've always done this sort of job of my run-around cars myself. I'm lead to believe that there are some extra shims in the front brakes and that they need to be fitted exactly right or you'll get brake squeal(?).
Can you recommend a make of disc and pad and where to get them from (I'm in south Wales). Will I need to bleed the system afterwards?
My independent has quoted me about £300 per axile (+VAT). I'm sure that I could get all the parts for less than £150 and do the job myself.
