As the title, need to replace the door seals. How easy is this to undertaken and how long will it take me?
Replacement door seals
- Thread starter RugbyBodders
I have done the door seals a couple of time on my 1973 911E. The key is getting some good glue. I use Frost contact adhesive. Most of the time is spent getting the old glue off. Then apply the glue to the seal and the shell. Make sure you do not stretch the rubber as you put in on as you will be left with excess. When fitted close the door and leave it over night. I would say it takes 3hours or so. You might need to remove the rubber foot protectors to get a good fit.
